  • 4 Replies
  • 1489 Views
Bing1974
Hi, can anyone help me with this issue.
We set up 'grant access' for another user but we are having issue with accessing to the live streaming at the same time. If the other user is live streaming, I get constant buffering till the other user stops live streaming. It used to be okay but the recent weekly, we couldn't do living streaming at the same time. Any advice?
BrookeN
Do you have the cameras set up for the authorized user to view them? Can you try removing the authorized user and then try re-adding them?
Bing1974
Thank you for the reply, when the authorised user is accessing to live streaming, I (the account holder) cant live stream at the same time, all i get is constant buffering. It seems that we cannot do live steaming at the same time.
BrookeN
Can you try to remove the user and re-add them back on?
Bing1974
okay, I will try tomorrow as they need the live streaming tonight. Many thanks.
  • 4 Replies
  • 1490 Views
