Is there a PARTICULAR SSD or flash drive (name brand so I can order it) that is confirmed to work with the Arlo Pro 4 (VMB4540) with the specification of 2.0 compatibility and Type-A connector?
Not really but I've used a variety of thumb drives, USB 2.x and 3.x, with no problems. I tend to stick with name brands but have also used some generic ones. I would also recommend the thumb drive rather than an SSD for this usage - the power supplied by the port may be an issue.
Arlo Pro 4
labels
Samsung SmartThings
