Arlo Pro 4 XL night vision stopped working
- 2
My outside backyard and garage cameras night vision stopped working. Inside camera works fine. If I go into the app and turn off night vision and turn back on then it works for the night but the next night it stops working again. The same thing happens if I reset the base. I tried removing the batteries and cameras from the system and then re-syncing but that didnt work either. I recently opted to record all footage locally using my Arlo base station and hard disk instead of using their subscription service. Seems it was working fine before my subscription expired but not 100% sure that has anything to do with it. I bought these from costco and am just about to return them if I cant resolve this issue.
The garage might be the best place to troubleshoot - in part because is it darker there, and in part because the spotlight is turned off.
@trburkiz wrote:
Ok interesting finding using garage camera. Went black with night vision off but still provides sound. Put towel over camera and night vision still didn’t come on. Spot light would not turn on manually from app. In addition microphone and speakers not working. Once I turned cam off and back on again in app every thing started working. I don’t think we are dealing with light sense issue. I think it a connectivity issue.
One of the mods will have to tell you about the logs - I don't work for Arlo, so I don't have any information on that.
It is possible that the camera is actually in NightVision mode, but that you aren't getting any video due to a connectivity issue. The easiest way to test that is to move the camera to a spot where signal isn't an issue - perhaps a closet inside the house.
Please reach out to the Support Team to further investigate this connectivity issue. You can find several options for contacting support though the Arlo Mobile App by navigating to Settings/System/Support.
- 2
Arlo Pro 4
labels
Samsung SmartThings
