Arlo Pro 4 XL badges on the app icon not working
I have Arlo Pro 4 XL, I am on iPhone iOS 17.1.2. The Arlo notification has no problem to show in notification center, but there is no badges on the app icon. Any help is appreciated! Thanks!
Under settings within the iOS app ~ then under Arlo, is the badges turned on?
Yes the badges is on. Thanks!
Uninstall the app from the library ( if it says remove app you are in the wrong spot) Reinstall the app and see if the behavior is resolved.
I tried to delete Arlo app (can't find uninstall) from library, then reinstall the app, but same issue occurs. Thanks!
If you swipe left on the iPhone until it shows library and then hold down the Arlo app it will say uninstall. Let's try to do it that way first.
After hold down the Arlo app, it only lists the following:
Delete app and then reinstall it from the App Store. Then sign back into the Arlo app and see if the same behavior happens.
Thanks! I deleted app and then reinstalled it from the App Store, but still having the same issue.
Are you able to see those badges now?
Unfortunately, still no luck.
Which iPhone are you using?
Thank you for providing that information. I passed this onto our development team and will reach out with an update as soon as possible.
'Are you still experiencing this same behavior?
Yes
I have not received any updates from development team yet.
Can you try logging out and logging back in. I know it seems like a simple fix, however I was seeing this same behavior. And that resolved it for me.
Arlo Pro 4
labels
Samsung SmartThings
