Hello, does anyone know what is the weight difference for the Pro 4 XL vs Pro 4? I saw the previous discussion saying that it can‘t use magnetic mount on XL since it’s too heavy. Can I use the anti-theft mount?
Why the bundle comes with a Hub? My understanding is the Pro 4 doesn’t need the hub. Has anyone have the XL model? Should I go with the Pro 4? I like the magnetic mount though. Not sure what to buy. Costco has an amazing deal for the XL right now, $150 off.
Thanks,
FWIW, the normal Pro 4 has steel in the back of the housing that is needed for the magnetic mount. The XL housing doesn't have that. So it can't be used with any magnetic mount.
No. The antitheft mount has an integrated housing, and that is for the normal Pro 4 - not the XL.
You can use other standard screw mounts.
I have some Ultras that I've upgraded to XL (along with some that I haven't). The XL battery definitely gives a lot longer battery life.
Thanks for info.
Arlo Pro 4
labels
Samsung SmartThings
