I would like to purchase the new Arlo Pro 4. Since it doesn't require a Hub, can each camera be used at a different locations? For example my home in one state would use two cameras and second home in Florida would use one camera, each location then having their own internet wi-fi service? Ideally, I'd like 2 cameras at each location, the base package has three, and I'd likely add an extra camera (either now or in the future) so as to have two at each of the locations. Hopefully, only one Arlo account would be necessary if I could do as I am questioning. Thanks!
Yes, this would work fine. Remember that after the 3 month trial for each camera is over you'll need a subscription so you can get cloud recordings.
Arlo Pro 4
labels
Samsung SmartThings
