  • 4 Replies
  • 1854 Views
Kproto
I keep seeing the April 2023 update and when I hit install nothing happens… I can’t see live screen as it keeps telling me to install it. I’ve restarted the device and removed it and re-added it to system with no luck.  Device is useless at this point.
It should install by itself so perhaps wait a day or so, and see if that happens.
Kproto
It’s been days … and it doesn’t install
I you have a subscription, then you could try phone support.
Kproto
Support tried.  I lost track of devices I tried it on, all the permutations of restart/reset/delete/add, using hub, not using hub, sending logs, etc.  it’s now unplugged in a drawer not working.  I bought a different camera and it works and updated just fine as do the other 5 I own.  This one is just fubar. What a waste of money. I’m now out hundreds of dollars because it won’t update.  Very frustrating.  I used to recommend these to everyone… not anymore.
  • 4 Replies
  • 1855 Views
