Arlo 4 - false detections at 1 sensitivity
I have a single camera that is detecting non existent motion. I have reduced the sensitivity to 1 to no avail. Also taken the camera off the app and reinstalled. Activity zone placed at an absolute minimum. Customer service has not been able to help. Any ideas?
How often is this happening? Sometimes the PIR sensors might trigger, even with nothing visible in the field of view. But this shouldn't be happening often (especially with sensitivity set to 1).
If this is happening very frequently, I'd first try moving the camera to a different spot - confirming that it is a camera problem, and not something odd happening at the location.
Assuming it is the camera (which seems the most likely possibility), I'd ask support for an RMA.
@ArBengal wrote:
I have verified that it happens even when inside the home. Battery lasting a day only. I can’t get any response from customer support after my first inquiry. Are they just non responsive?
Perhaps @JamesC, @Mark_V, or one of the other Arlo folks can help you escalate the case. They'll want the case number.
Arlo Pro 4
labels
Samsung SmartThings
