  • 4 Replies
  • 1351 Views
ArBengal
I have a single camera that is detecting non existent motion. I have reduced the sensitivity to 1 to no avail. Also taken the camera off the app and reinstalled. Activity zone placed at an absolute minimum. Customer service has not been able to help. Any ideas?
How often is this happening?  Sometimes the PIR sensors might trigger, even with nothing visible in the field of view.  But this shouldn't be happening often (especially with sensitivity set to 1).
If this is happening very frequently, I'd first try moving the camera to a different spot - confirming that it is a camera problem, and not something odd happening at the location.
Assuming it is the camera (which seems the most likely possibility), I'd ask support for an RMA.
ArBengal
I have verified that it happens even when inside the home. Battery lasting a day only. I can’t get any response from customer support after my first inquiry. Are they just non responsive?
Perhaps @JamesC, @Mark_V,  or one of the other Arlo folks can help you escalate the case.  They'll want the case number.
ArBengal
Case number is 42604531. If they could help I would be very grateful. I bought two separate systems for 2 different locations and all are working properly but this single camera.
  • 4 Replies
  • 1352 Views
