Are there any alternative mounts for the pro 4?
  • 1 Reply
  • 830 Views
JohnWick75
Are there any alternative mounts for the pro 4 since it does not have threaded inserts like the pro 2's had. Seems like I'd have to get a new case. Any help appreciated.
Actually the standard Pro 4 does have the same threaded sockets.
Do you have the one with the security mount?  You can buy replacement housings with the threads:
They say pro 3/ultra, but the same housing is used with the pro 4.  Note "Compatible devices" includes the Pro 4.
If you have an XL (or want to upgrade to the XL battery) you could also get this:
  • 1 Reply
  • 831 Views
