Alerts ping to often any way to reduce/remove the constant alerts? (Dusk to dawn) or other signal?
Retired_Member
Not applicable
2021-04-24
08:16 PM
Limit the pings and consistent alerts, or reduce the frequency as it goes off every car, and pedestrian.
With fencing, it still was too frequent.
Arlo Pro 4
Did you try reducing the motion sensitivity?
Adjusting the camera position is another option.
Retired_Member
Not applicable
2021-04-25
11:30 AM
Yes, reduced to just pedestrian, auto and set zones.
Helps some, but seems to go off with wind, noise etc. Working on that but seems hyper sensitive.
Arlo Pro 4
labels
Samsung SmartThings
