Adding to Pro system with base
  • 1 Reply
  • 1095 Views
marentette2525
I have the pro system with 6 cameras going (I have the base hub).  I would like to replace one of the pro cameras with a pro 4 for better clarity on the driveway.  Are pro 4’s able to be added to a pro system?
Pro 4 cameras can be added via your home wifi, so it can be added no matter what the base station model.
If you do want to pair it with your existing base, then the answer depends on the base model.  Look for a VMBxxxx label on the base.   Then check the compatibility info here:
  • 1 Reply
  • 1095 Views
