  • 4 Replies
  • 2361 Views
  • 5 In Conversation
m-j-g
when i am trying to connect my camera i scanned the qr code all good and then whilst arlo is finding/connecting the camera flashes blue then orange then goes off? Arlo then says camera cannot be found.
Is the battery flat? or wat have i done wrong?
m-j-g,
Be sure you are entering the SSID/Password for your network correctly. Also be sure the battery is fully charged and try onboarding again. Do you still experience the same behavior?
Pro4problems
Im having the same problem that you responded to earlier,
"when i am trying to connect my camera i scanned the qr code all good and then whilst arlo is finding/connecting the camera flashes blue then orange then goes off? Arlo then says camera cannot be found.
Is the battery flat? or wat have i done wrong?"
your suggestion was to,
 "Be sure you are entering the SSID/Password for your network correctly. Also be sure the battery is fully charged and try onboarding again"
my wifi details show that there are two cameras connected to our internet system, so the password is correct. The cameras are fully charged as well. Yet, when I Arlo begins looking for the device(s) after reading the code, orange light flashes and cuts offline.  I have synced using the button to try to maintain connection after this happens, but, Device Fails to connect every time.
help would be so appreciated, thanks and best
lms911
Is there another solution to this?
JLM78
I am experiencing the exact same issues. Were you able to install the cameras in the end? What trick did you use?
  • 4 Replies
  • 2362 Views
  • 5 In Conversation
