2K/4K Videos cannot be played in browser
  • 2 Replies
  • 5302 Views
  • 2 Likes
SQLPolice
Hello,
Notification Videos from my Arlo Pro 4 can cannot be played in Browser.
Error Message: This video is not able to play in your browser. Please download to view.
Tried with MS Edge and Chrome. Both on Windows 10, everything on latest updates.
In the Android App , it works.
What can I do? Is it a browser setting?
Kind regards
First, check the PC's processor.  You need at least a 6th generation AMD or Intel processor to play back HEVC.  If you don't know how to check that, then right-click on "this PC", or enter "about this PC. in the search bar, and open the settings.  You will see a screen that includes the processor information:
With Intel, the processor generation is easy to see - in the sample above, the processor is 10th generation (i7-10610U).  If you aren't sure though, just post the processor details in a reply.
If your processor is new enough, then go to the Microsoft store, and install Microsoft's HEVC extension for windows.  There is a small cost ($0.99 USD).  After that, you will be able to play the videos directly in Edge (but not FireFox or Chrome).
SQLPolice
Thanks! My PC has a Gen 4 CPU - that explained it 😉
  • 2 Replies
  • 5303 Views
  • 2 Likes
