local storrage record everything
Hi
I'm very new to the Arlo universe, and jus bought 3xpro 3 with base station.
I set one camera up, over my driveway, and set the area in the app, so it should not registrar the road. Also I set the detection zone within the camera area.
BUT it keeps recording every time a car goes by on the road, thereby filing the usb stick and draining power from the camera....any ideas
@Allan_t wrote:
Hi
Activity zones are processed in the cloud. So they supress cloud recordings, but not the local ones on the USB stick - and as you rightly say, they don't help battery life.
Options are to
- adjust the camera so the cars aren't in the field of view
- reduce the motion sensitivity
In my experience, option 1 is the best approach.
