  • 1 Reply
  • 1201 Views
daveyagow
do you need to charge the batteries on initial set up, and how oftrn do you need to charge the batteris
The batteries prob come shipped with about 80% charge ( normal for li-ion cells ) so YES, I would top them off.
How often you need to charge is more based on usage. If you record alot, you'll need to recharge sooner.
Most of my cameras go 2+ months of normal use.... low use cameras go 3+
Spec usage is 5 mins per day or less of record or live view
  • 1 Reply
  • 1202 Views
