arlo pro 3 notifications
You could go to smart notifications and uncheck people notifications for that camera. It will still record but you will not get notifications. There are three choices, People, Animals and Motion, just uncheck what you don't want.
That's what custom modes and the schedule are all about. Create as many custom modes as you need for different time periods with appropriate settings in each rule (turn off notifications for the inside camera for daytime use) and then schedule them to automate the switching. There are FAQs here detailing this and many other topics in the support section. Remember that any camera without a rule is disarmed.
^^This, set up a custom arm/disarm. You can try setting up geofencing
Thank you, at the beginning that is what I was trying to do but it either let me select push notification or email it had to be one of both. so now I wasnt getting notifications but my email was getting bombarded after many many tries of setting up a custom mode it finally worked.
thanks for the help
