Try and test via a browser at My.arlo.com and eliminate the system itself is not having an issue.
@64Scott wrote:
Any support from Arlo?
The mods might chime in, or you could use the support link in the upper right of the forum page.
You've already tried the usual stuff (reinstall the app, restart the phone). Not sure what else to suggest, other than maybe restarting the base.
What's the 'key' icon in the top left corner? Are you connecting via VPN? If so, try switching VPN off.
Also, the shield icon in the top left corner - is it some kind of anti-virus? If so, maybe it's blocking the connection, as it sees it as 'untrusted'.
Clearly, it's your phone's network settings that are blocking the connection, making you unable to access the Arlo app.
