VMs 4440b compatible with ultra cams
  • 5 Replies
  • 5333 Views
ThomasLarsen
I’m about to buy a pro 3 bundle and I’m curious...
Can I ad ultra cams to this vms4440b hub or do I have to buy a bigger hub and then ad the pro 3 cams?
I don’t want tho spend the extra bucks right now for a ultra bundle, that why I ask.
Regards Thomas
dcfox1
5 REPLIES 5
dcfox1
ThomasLarsen
Hi,
But the 4440 isn’t mentioned there...
dcfox1
I found the VMC4440P in a online  support search here and the link just goes to page not found. So not sure if it a overseas version or a discount store version but I would think it would be in the 4000 series but not sure. Mabey a moderator or someone will chime in or call support below to check.
The VMS4440B is a system, not a base or hub. Those would use the VMBxxxx naming. Since the VMS4440B is a Pro 3 system, you can add the Ultra camera with no problem. I can't tell for sure what hub it is but I suspect it's the VMB4540.
Arlo Pro 3 kits include the VMB4540, which is compatible with Arlo Ultra cameras.
  • 5 Replies
  • 5334 Views
