VMB4540 not recording locally intermittently
Does anyone else have problems with the #VBM4540 Hub randomly not recording locally motions? I get notifications but it does not record but then the next one will record
Message 1 of 9
573
8 REPLIES 8
Hi @Wewillyw
Does this happen consistently?
May I ask which troubleshooting steps you have tried so far? I don't want to suggest anything you have previously performed.
Message 2 of 9
553
I have tried clearing the USB Flash Drive, and I have tried doing a full format on it as well.
Message 3 of 9
546
It does happen fairly regularly,
Message 4 of 9
545
Yes it happens fairly regular, couple of times a week.
thanks
Message 5 of 9
484
Always with the same camera?
Message 6 of 9
482
no
Message 7 of 9
479
It may be fastest (but a PITA) to remove the hub and all cameras connected to it and set it back up as if new.
Message 8 of 9
463
Thanks, I will give that a try once I get some time on my hands.
Message 9 of 9
448
