I have pro 3 cameras. They will record but they will not show live. Says "Device apprears offline.
Did you try restarting the base? Also restart the cameras by removing/reinserting the battery.
I did try and restart base. I have not removed and reinserted battery. I'll try that.
@Adobefats are you still seeing this same behavior?
You'll get some basic troubleshooting steps in here and if you contact Arlo support in India they'll just do the same thing. Then once they have no idea how to fix your issue they'll just stop contacting you. You better off going ahead and looking for a different product.
