Base light is solid blue but status says hub is offline. Have unplugged power cord and ethernet cord (changed it as well) and rebooted hub. Blue light comes back to solid blue. Have full connection on router, the device pops up in the router but no traffic seems to be getting thorough.
Can´t seem to factory reset it. try to do that but the LED stays Solid blue. Any ideas or do I need to buy a new base?
It hase worked fine for 3 years before this happened.
Could it be anything on the router?
best regards
Simon
Have you tried both the app as well as the web client to see if there's a difference? For the app, have you tried both WiFi and cell service?
The factory reset, like pretty much any other reset procedure, requires that you hold the button until something happens, in this case the LED starts flashing amber (~15 seconds of holding).
https://kb.arlo.com/1057976/How-can-I-reset-my-Arlo-SmartHub-or-base-station-to-the-default-values
If you do that you also need to remove all devices from your account and start fresh, as if you just bought the system.
Yepp. same result with web and the mobile app.
Nothing happens holding the reset for 20 sec+ . Blue Led still just lit.
All devices have been removed and the base as well, and it can´t be detected for new installation
Can you feel/hear the button click when you push it?
Yes, clearly. Feel like the whole thing is frozen since the led turns solid blue whatever i do
Depending on which user interface you are using, use Settings, Support if you see Library to view videos, or Settings ("person" icon top left), Support Center if you see Feed instead. Select your hub model to contact official support. This requires that you have a subscription.
yea, now i have removed the device so can´t reach anything. And no subscription so guess all that is left is to buy a new one
Now that i press the HW reset button the LED turns stable orange ( not flashing) I think I need to buy a new one 😉
As a last gasp before spending money, check the output from the power supply with a voltmeter to ensure it's supplying what is noted on the supply itself (I think it's 12VDC).
Good point, will do that as a last resort 🙂
Seems to be delivering power as it should... will order a new one and hope it works 😄
						Arlo Mobile App436
						Arlo Pro 37
						Arlo Secure2
						Arlo Smart317
						Before You Buy296
						Features402
						Firmware Release Notes4
						Installation363
						Online and Mobile Apps15
						Service and Storage17
						Troubleshooting1,882
