Trigger multiple cameras from one event
  • 1 Reply
  • 1510 Views
GMGK
is it possible to trigger all cameras to activate simultaneously when motion is detected from one of the cameras?
Yes.  I call that cross-triggering.  You go into the rules in the mode(s) you use, and then modify each rule to record on the additional cameras.
Note that a smarthub only supports 5 simultaneous streams, so don't over-do this.
Best answers
  • StephenB
  • 1 Reply
  • 1511 Views
