is it possible to trigger all cameras to activate simultaneously when motion is detected from one of the cameras?
Yes. I call that cross-triggering. You go into the rules in the mode(s) you use, and then modify each rule to record on the additional cameras.
Note that a smarthub only supports 5 simultaneous streams, so don't over-do this.
Best answers
