The latest update to my base stations 1.21.0.0_1377_a58d08a has stopped notifications from working.
At first only one updated a week or two ago and stopped notifications for cameras connected to it, now the other two have updated and are showing the same problem. Anyone else experiencing this?
Please reach out to the Support Team to further investigate this issue you are experiencing. You can find several options for contacting support though the Arlo Mobile App by navigating to the Profile icon > Support Center > Select device > contact
Yes, mine stopped recording all of my zones. I can manually record and it will show up in my library. If I reboot the base station it starts working again for a short time and then goes back to not recording. Cameras are all accessible and not offline.
Please reach out to the Support Team to further investigate this issue you are experiencing. You can find several options for contacting support though the Arlo Mobile App by navigating to Settings/System/Support.
