TCP and UDP number
What are you trying to do?
Set up Direct Storage Access?
What is Direct Storage Access and how do I use it?
Start with your router? What is it?
In my case, it set itself to TCP/UDP protocol. It was a case of picking something from a list of devices.
Just another user
Thank you for your reply.. i think i figured it out with the help of my IT friend. The call centre agent from my internet provider does not know what he was doing according to my friend that is why.. My friend directed me where and what to change on my router’s settings and the port forwarding is working finally..
That's good. It shouldn't be that difficult but Arlo's guidance is not great. Even experienced users can have problems.
Why does that not surprise me? But to be fair to them there is just too much stuff out there for an ISP to know about everything.
Just another user
Could you share the solution you used to fix yours? I've been having a hell of a time trying to fix a heavy pixelation issue with my Arlo baby for local viewing on the UDP protocol. Remote viewing using TCP is completely fine, but local viewing is next to impossible most of the time, and it drops the connection from time to time. I'm using a netgear orbi ax4200 as my router with a satellite in the same room as the baby monitor. No issues on range...
I have no problem with my local viewing so i did not touch anything on the UDP setting sorry.
