I’m trying to use cameras bought in the US and the system will not verify since billing address and country use are different … suggestions?
Where you bought the cameras doesn't matter - what country you're in when setting up the system does.
Since only specific countries can purchase a subscription you can use a VPN that terminates in a supported country to create your account and set up the system. You'll also need a credit card from that country to use for any subscriptions. Once the system is set up you can disconnect the VPN and use the system normally.
BTW, you could have set the system up while in the US, turned it off and finally set it up at home where it would work without the need for the VPN.
