I have the siren fuction switched off on all my cameras. Late last night the siren began to sound on my front camera, which sees a lot of traffic. It continued to sound for some time until I switched the camera off. I checked everything this morning and confirmed that the siren was switched off. Can anyone explian what the problem might have been and what I need to do to prevent a repeat
barryhill,
Are you continuing to experience this behavior? You might want to try removing and resyncing the camera.
Thanks for your help. This has not happened again, but I will try this if it does. The main problem I am experiencing is that the hub light keeps flashing amber. Mostly it returns to solid blue, bur occasionally doesn't. I have found that switching off power and reconnecting solves problem
