  • 1 Reply
  • 212 Views
RandomRaccon
I am attempting to reconnect an Arlo Chime to trigger when motion is detected on an Arlo Pro 3 camera.  I had this set up correctly a few years ago, i seem unable to link the chime to a non-door bell camera.  What are the correct steps to set up this trigger?
Fyi, there is a base unit that everything wants to connect to, previously i think the chime linked directly to a camera.
Thanks for your time and insights!
-a random raccoon
DO you use Library or Feed to view recordings? The answer may be different depending on your answer. If using Feed, go to Routines, Modes and edit any modes that have a rule for the Pro 3 camera. Use Ad an Action and choose Play a Sound. Choose your chime and set the desired sound. Be sure to save as you complete the new setting. Test to be sure.
  • 1 Reply
  • 213 Views
