I have checked Settings -> Privacy and ensured both the Arlo Hub and Apple TV are on the same switch, both hardwired.
The fix for this issue has started rolling out. Please update your Arlo mobile app manually from the iOS store to version 3.5.1 and if you're still experiencing the issue, reach out to me in a private message with your e-mail address and I can send your system a HomeKit token reset.
Thank you,
I have exactly the same problem! Arlo, please can you please fix this issue?
The development team is currently investigating this issue. I will provide an update once more information is available.
I have also recently received a new base station that once installed cannot complete the “Requesting HomeKit Information” pairing. The ARLO APP continues to spin and does not even time out. I would prefer not to return the equipment if this is a known software issue that will be addressed in an update, but I don’t want to run out of the 30 day eligibility to receive a refund on a non-functioning item.
Are there any updates on this issue?
Same issue here. The Arlo app hangs on Requesting HomeKit info… indefinitely. I have two VMB4540 hubs, both purchased recently. I added the first one about one month ago with no issues.
I’ve been trying to add the second one for the last two weeks with no luck due to this issue. It’s possible that I updated my iOS devices in the meantime. I’m currently running 14.6.
Now I understand what changed from a month ago when HomeKit integration used to work: Arlo released a new app version, 3.5. There’s also another thread about this issue, starting right when the new app was released.
It sounds like a few people have escalated this issue with Apple but Arlo is not being responsive to Apple’s inquiries. Arlo, if you can’t respond with a timeline for a fix I’ll have to return all of my cameras and hubs as defective and buy something that works with HomeKit.
For anyone reading this before purchasing: Arlo HomeKit integration is currently non-functional.
Seriously? That’s the same response over and over. We deserve to have a detailed explanation of the issue and the time frame for fixing it. We also deserve to know where on the scrum list this issue is. You sold this product with functionality specifically stated as compatible with HomeKit. I bought this about 10 days ago and from out of the box it was not compatible and this company knew it.
Provide the information please.
Thank you,
