Question about LED on Dual Charging Station.
The LED light has been amber for the last 2 hours without changing colors. When I remove the batteries they are very warm then when I return them to the charging station the led light still does not change colors
I don't think two hours is enough to fully charge the batteries.
Though it is odd that they are so warm.
You could try putting one back in the camera, and check the charge level. Maybe also leave the second in the charging station a bit longer, and see if the LED changes.
