Pro 3
How can I change the time on the system. The time doesn't change with the daylight savings time.
It should.
The answer depends on whether you see "Libary" at the bottom of the app, or whether you see "Feed" instead.
Also, where are you? There have been some recent posts involving folks in the NZ/Australia with this issue but I'm not sure if it was resolved.
