Pro 3 - stopped working, constant blue light on device
  • 1 Reply
  • 649 Views
DotFitz
My camera just stopped working. Full battery. There is a blue light on device constant. Don’t know if it was there before but now just not working anymore.
What do you mean by it stopped working? You aren't getting recordings or is it offline? What happens if you remove the battery and reinsert it? What happens if you remove the battery and use only AC power?
  • 1 Reply
  • 650 Views
