Pro 3 blank recordings
Taghut02,
Thumbnails are not available for locally stored content. If you eject the storage device and view from a computer, are you able to view the clips?
Same issue here. It worked fine until a few days ago. Now I can see some recordings in my IOS app, but most of them appear blank. Recordings are on the USB as I can view them on my home computer. Issue for both of my cameras. Please fix.
I fixed this problem by using the option in the Arlo app "Delete downloaded video's" This does not delete them from the cloud or base station, but only in the app. Afterwards my video's were available again and I could download them.
By using the option in the Arlo app "Delete downloaded video's" worked for me as well. Seems to be a bug in the app software. Thanks for the tip.
It must be a bug.
In the beginning I had no problems watching the USB stored videos. But after some time almost all were grey.
After deleting downloaded videos from the App all videos work again.
Please Arlo correct the bug.
Thanks so much for this great advice much appreciated, i’ve been trying for months to find a fix to this issue, i just now clicked delete download video’s, wow i can finally download and actually view my usb stick stored video’s without them all black screening.
