Pro 3 SmartHub Not Connecting to Router
  • 1863 Views
pritcharddesign
I have an Arlo Pro 3 Wire-Free camera system with SmartHub.
Router # VMB4540
System model # VMS4240B
I'm on a Mac.
SmartHub is not connecting to router. After first connected, I get a solid blue light for a second, then it goes to blinking amber.
Also, after putting batteries in cameras, there's a blue light, then it goes away. Does that mean the battery needs charging or it's not connected to the SmartHub?
Documentation is lacking & confusing!
pritcharddesign
Thank you.
Operator error...I was plugging it into the modem, not the router. 😤
My tech guy passed away last year and I'm figuring this stuff out on my own.
Thanks for your response!
pritcharddesign
And I only received one mount with two cameras!
For the hub, hold the reset button for >10 seconds until the LED flashes amber. Let it reboot and see if the LED eventually turns blue (~2 minutes).
The camera LED will flash blue when first inserting the battery to indicate that power has been applied. A low battery will cause a slow amber blink but I'd start with charging the battery first anyways. The default setting is for the blue LED to come on solidly when fully charged in ~3 hours.
pritcharddesign
Thank you.
  • 1864 Views
