  • 809 Views
LLantz
My Pro 3 Floodlight will not securely attach in the housing. Did read two older posts saying use silicone lubricant on the O ring but there isn’t anything in the housing or camera to lubricant. There are no broken pieces.. it just wants to slide right back out instead of attaching no matter how hard I push it into place.
Mine has a tendency to do that also.  Unfortunately the only option is to press a bit harder.
LLantz
Thank you. I found the O Ring. It’s so hard to see! I lubricated it lightly and the Floodlight clicked right in!
Great!
  • 810 Views
