  • 1 Reply
  • 1169 Views
Stan777
Hi all, question has to do with base station and Alexa. I can disarm my cameras using voice code fine. But when I want to create a routine, the only options that come up under base station are “arm stay” and “arm away” vs Arlo usual arm disarm. Almost as if Alexa thinks the base station is an alarm panel.
Anyway I tried creating. Routine with the arm stay away commands and doesn’t work - not surprised. Tried removing skill, removing and re adding base station. All of the obvious fixes, no luck. Thoughts?
ShayneS
Please reach out to the Support Team to further investigate this issue you are experiencing. You can find several options for contacting support though the Arlo Mobile App by navigating to Settings/System/Support.
  • 1 Reply
  • 1170 Views
