  • 6 Replies
  • 1461 Views
KimBowden
Hello, I am having issues with poor connectivity from my base to camera. I’ve installed a BT wifi booster to help but still having problems.  I want to remove connection to the base and connect directly to the booster. When I try to connect the only option I get is to connect to the base, the manuals suggest I should be able to click on connect without the hub … but the option doesn’t appear.
Does anybody have any suggestions please?
6 REPLIES 6
KimBowden
I should also add that I have a wireless doorbell as well, and that has connected to the booster without any issue and is working well.
There's no way to do that with Pro 3 cameras.
KimBowden
Thanks for the reply StephenB.  I was following an online manual at - https://kb.arlo.com/000062379/How-do-I-connect-my-Arlo-device-directly-to-my-WiFi-router-if-the-came...
which makes no mention of not being able to do with the Pro3 series, so very disappointing for lack of info from Arlo.
But many thanks to you for replying and letting me know, appreciated.
kind regards
KimBowden
Hi again Stephen, thinking about it … can you perhaps tell me please, which Arlo cameras are able to connect directly to the booster, instead of having to connect to the Homebase unit?
Kind regards,
Kim
The Pro 3 floodlight (not the ordinary Pro 3), the Pro 4, and the Essential cameras can connect directly to your home wifi (e.g., the booster).  All require a paid subscription to get cloud storage.
Also the new Go 2 camera can connect to your home WiFi or via LTE.  Again, it requires a paid subscription to get cloud storage, and also a data plan if you want the LTE connectivity.
KimBowden
Again many thanks Stephen. Really appreciate it.
kind regards,
Kim
  • 6 Replies
  • 1462 Views
