Plugged in CVR Camera at 85%..?
  • 4 Replies
  • 2635 Views
Steel22
I have a Camera thats plugged in 24/7. And have the CVR plan on it.
But recently noticed it is holding steady at 85% for a couple days now. Instead of 100%
Is this something i need to be concerned about?
If so.. What do i need to do?
Steel22
Yeah. It had the bolt still on it. So was still charging. And was using the app.
But it fixed itself. Musta just been a glitch.
Thank ya tho.
Are you using the app or web client? Does the battery icon show a lightning bolt over the battery? Have you logged out and back in to see if the display updates?
Shaun1234
Virtuoso
Virtuoso
Mine does this, its just a glitch doesnt effect anything, if your worried just power off camera for a while then it will return
Steel22
Thank ya tho.
Steel22
Yup. Musta just been a glitch. Fixed itself.
Thank ya tho.
  • 4 Replies
  • 2636 Views
