Outdoor power for the Arlo Pro 3
  • 1 Reply
  • 609 Views
Resqdyn2
I have a number of Pro 3 outdoor cameras. All are using the solar charging option. I have at least two I’d like to change so they are powered from the house. The 25’ outdoor cable doesn’t have enough reach to get me through the turns and curves to the nearest outlet. Is there a solution to link two 25’ cables together or a cable longer than 25’
Generally that wouldn't be a good idea due to the longer length causing a larger voltage drop over the increased distance. The outdoor chargers are designed with the voltage drop being considered. You may need to get creative to get power to the chargers - some folks have drilled holes to do this.
  • 1 Reply
  • 610 Views
