No notifications for local storage
Hi
After i went from cloud to local storage I don’t get any notifications when camera detect movement? It used to work fine up until I switched to local storage
And do I need to setup port forwarding to be able to see the recordings when I’m not on my wifi?
1) Are notification enabled in your modes and rules? I believe they are supposed to work even without a subscription.
2) Yes, you need to be on your home network to see local recordings. You can do this by setting up a VPN (if your router supports it) or by port forwarding. If using port forwarding, I'd suggest setting a static IP address for the hub since otherwise the router could assign a different IP address to the hub after hub and/or router reboots.
