No Sound on Library Recordings using app/iPhone
I have several videos now where recording was triggered based on audio detection, but no sound appears on the recording.
This is an intermittent problem. Some recordings from today have sound, others do not.
This is a huge problem because part of why I need this camera is to document sound problems.
Can someone help me please fix this?
I just checked the cameras again... sound is intermittent on live feed also using ARLO App on iphone
ktagliam,
It's possible extremely low, barely audible sound is causing a trigger which makes the resulting video appear to not contain any sound. What is your sensitivity setting for audio triggers? You may need to adjust this until you have the desired results.
The sound is not present for both my iPhone library and for my library when viewed from my PC. You can also hear sound then it abruptly cuts out, mid video
You should reboot your base and see if that clears it up
No problem. Hope the reboot helps you.
For my issue, there was no sound on the downloaded file, either
@Nichols55 wrote:
After hearing sound on live view, I switch back to my library and the sound magically works. No idea how or why. Such a hassle!
Freaky. But it does smell like an iPhone issue. Could be the App, but I can't recall reports of similar behaviour.
Just another user
James, this is not the issue. The audio works fine for me, as long as I use HEADPHONES on my iPhone. As soon as I remove the headphones, there is no audio playback, only video. I keep looking for the mute button, but there is none.
I have the same issue, only I noticed that the audio plays back fine when using headphones plugged into my iPhone. When I unplug the headphones, the audio goes silent. I was trying to let my partner hear the audio, but it was as though it was muted. There doesn't appear to be any way to "unmute" the audio.
This was definitely working before. Judging by the date on the OP, I would say that an update around May of this year has caused the issue. I didn't use the app for a while, so can't say for certain.
