New feature??
  • 1 Reply
  • 939 Views
jsaus63304
Luminary
Luminary
I previously suggested that we should be able to default our library to local storage rather then cloud.  I just discovered that if you look at your Smart hub/Base under devices, there is an icon next to the settings gear.  If you click on it, it takes you directly to local recordings for all cameras.
Maybe this has always been there but just noticed after the last recordings fix.
Yup, it's been there for a while now. I don't recall if it happened immediately when we could use the app to directly view local recordings but I think so.
  • 1 Reply
  • 940 Views
