My camera is not charging
  • 1 Reply
  • 863 Views
Marlang1969
Need all details as to what you've tried and what you see. Are you using the Arlo-supplied charger? Have you wiped the connections on both the cable and camera?  Do you see the lightning bolt through the battery when the cable is connected? If you have more than one camera, have you swapped batteries around?
  • 1 Reply
  • 864 Views
