Multiple cams in one program
- Hi Community, I would like to use two cameras in one surveillance program. When I try to create a new mod I can only chose one camera which then triggers other cameras…. But I would like to use the motion detection and recording in two separate places. How can I create such a mod? Basically it would be like turning all cam on or off except that I don’t want all to be on and recording….
@Upic wrote: When I try to create a new mode I can only chose one camera which then triggers other cameras….
Each mode has one or more rules. In your case you need to add one rule for each camera.
It sounds like you are instead trying to put two cameras in one rule. That is used for cross-triggering (as you found), but won't trigger the cameras independently.
If you need more advice, it would be helpful to know
whether your cameras are connected to your home wifi, or whether they are instead connected to a hub
whether you see "Feed" and "Dashboard" in your app, or whether you instead see "Library"
