  • 1 Reply
  • 1254 Views
DMOA
I am having intermittent issues with one of my cameras connecting because of where my base station is located in the house. The base station is in the SW corner of the house, the camera I am having signal issues with is on the NE side of the house. Is it possible to buy a 2nd base station and have it on my same account? If so I was thinking of placing a second base station on the NE of my house extending the range for the camera that has poor signal?
Yes, you can do that.
You will need to remove that camera from your account after you add the second base.  Then add the camera back, connecting to the new base instead of the old one.
  • 1 Reply
  • 1255 Views
