I have the Arlo Pro 3 cameras, and I use smart notifications. I have everything except "All Other Motion" selected, but I'm constantly receiving "motion detected" notifications. Why do I have the choice to exclude getting motion notifications if my choice doesn't make any difference as to which notifications I get?
arlomg,
Does this always happen or is it intermittent? You might try rebooting your SmartHub and test again to see if you still experience the same behavior.
It doesn't notify for EVERY instance, but it happens frequent enough to be very annoying. I've restarted the base and cameras but I still get the notifications.
I just had to go and delete about 65+ 10 second recordings of nothing.
