Manual recording and taking pictures not working from the Mobile app. But it's working fine in a Web browser
Have you rebooted the phone and reinstalled the app?
Re-installing the app fixed. Thanks
I need to restart my phone every time to fix this issue. It looks like a bug was introduced in the last update. or at least needs a code fix, rather than restarting the phone every time.
I'd think that just force closing the app and reopening it would be sufficient. However, you seem to have a specific local issue that no one else is having. What phone and OS version do you have?
iPhone 6s Plus.
ios: 15.7.7
No iOS here so can't be specific. Is there a newer OS to be installed? Not sure that would help but maybe...
No. When got Software update
It says iOS 15.7.7. iOS is up to date.
What version of the app are you running?
App Version: 4.6.1 (6471)
Released: 8 Jul 2023
That is working on my iPhone 12 mini, but I am running iOS 16.5.1(c).
When you livestream a camera, are you seeing the record and snapshot icons?
Also - are you using the same account on the phone as you use on the PC?
No. I have to force stop and open the app then it will show icons and the next time it stops showing the icons.
Yes
That sounds like it might be bug in the app (specific to your iOS version, since I don't see it).
I'n tagging the mods ( @JamesC and @ShayneS ) to call their attention to your issue.
You could also try contacting paid support (via the app). No idea if they can resolve it, but it is another way to get the defect logged. Phone support is probably better than trying chat (it avoids dealing with the bot).
You are right because, On my wife's mobile, I don't see this issue. And She is using Version 4.5 (6272).
Sure, will call support. I already have a subscription so it should be free I assume.
