I have several Arlo 3 and Arlo Q and a homebase but no subscription.
I was able to look at my cameras and view footage from within 7 days - I did this as recently as a month ago to confirm something an employee said that happened in my store.
But now when I log in, I only see options to buy a subscription.
There is no trace of any of my devices or videos.
What happened?
Am I logging into the wrong portal?
my.arlo.com is the correct site (note you do need the . between my and arlo).
Are you sure you are using the correct account credentials?
Do you have the app installed on a phone or tablet?
You wouldn't see footage from a Pro 3 camera from my.arlo.com unless you had a subscription in force. I suggest that you confirm the camera model by opening the housing, and removing the battery. There is a label inside.
I am guessing that you actually have Pro or Pro 2 cameras - which do have 7-day cloud storage.
Ok, I was trying to view my cameras from the website.
However after I downloaded the mobile app and logged in, I now see my cameras.
So I assume I'll only be able to view Live and Footage from the app.
I'm not sure exactly what model I have. When I check Device Info it says H7. Another one says "6"
What confused me is that I have another account that also has the Arlo Q but I can view the cameras from the website.
The H revisions aren't useful - they are hardware revisions for a given model. Many cameras share the same H codes.
As I said earlier, open the cameras and remove the battery. Then look at the label.
If that is inconvenient, there is another way. Go into settings->support. Then select one of the cameras. Scroll to the very bottom of that screen, and you will see a product field that starts with VMC. Let us know what it says.
@rickas27 wrote:What confused me is that I have another account that also has the Arlo Q but I can view the cameras from the website.
Likely you shared the Q in that account with the one you are using. There's no good reason for you to be using 2 accounts, so I suggest you consider consolidating them.
That's not correct, there must be something else going on.
