I set up local video storage and access using the library. I was reviewing videos and access just stopped. I've tried everything, including suggestions in the community to reinstall the app and reboot my phone. Of course, I checked my USB storage, the base station, etc. Nothing has worked. I get the message box to "Please check your connections settings." Nothing changed and there are no problems with my local network or hardware that would have caused the problem in the first place. Any suggestions? Has this happened to anyone else?
If you have 8GB of space, that's the problem. You need at least a 16GB drive due to recent firmware updates.
I used it extensively this morning with no problems. Are you checking while at home or when away? Try a different drive to see if it still happens (>16GB). It's possible that you may need to reset the system and start fresh.
What did you use extensively this morning with no problems? I'm checking when I'm home on the local network, cause that how it works without additional setup. As mentioned, I was viewing videos when it stopped downloading in the app and hasn't worked again. Storage on the USB drive wasn't even close to capacity and I reformatted, so there are 8 GB of space, but will try a larger drive. I did may things to reset the system and start fresh including reinstalling the app. Other suggestions?
I switched to a brand new 32GB USB drive about five days ago, formatted it, restarted the app and phone, etc., but it didn't work. Was going to try again this weekend, but suddenly, it started working yesterday, so the problem is resolved, but not from any of my settings or configurations.
